Unknown problem with display (Vivobook Pro 15 OLED)
sheeshkinsheeshkin Level 1
edited July 20 in VivoBook
  1. System: Windows 11
  2. Battery or AC:
  3. Model: Vivobook Pro 15 OLED M3500QC
  4. Frequency of occurrence: Everytime
  5. Reset OS: Yes
  6. Screenshot or video:
Detailed description:
I've described my problem in this discussion:
After more than a month of repairing (screen matrix was replaced in local authorized service center) the problem with the display still exists. The phenomenon is not caused by a matrix defect.
Agents from local ASUS Support Center and local service center declared that this phenomenon is not a laptop defect. But they don't provide me with proofs and any technical information about this phenomenon.
I assume that the local office doesn’t want to solve this problem and try to convince me that this phenomenon is not a defect.
I want to know exactly why it's not a defect (technical information)? I want to be provided with full explanation of this phenomenon to make sure that it's really normal condition for my laptop.
You can check the problem in the video below:
It's random flashes (brightness changes for a moment). This issue happens just while moving a cursor. It's mostly noticeable on gray color on display (for example Windows Explorer with the dark theme of Windows 11). It doesn't depend on versions of chipset or GPU drivers and BIOS. It happens when AMD Radeon Adapter is enabled in Device Manager. The problem doesn't exist when AMD Radeon Graphics adapter is disabled. It also doesn't happen in safe mode and BIOS regardless of graphics adapter.
My opinion: the problem is related to the ASUS software and its driver conflicts.
UPD: This is not a PWM effect because I see the phenomenon on 100% dsiplay brighness.
«1
Comments
Sign In or Register to comment.
