Zenfone 4 Pro with audio level low
euro_pe
Model Name: Z01GD
Firmware Version: WW_ZS551KL_15.0410.1911.117_0
Rooted or not: NO
Frequency of Occurrence: with lata update
Neutron app level sound is good with headphone Grado.
PowerAmp, VLC, PlayerPro, WavePad, Musixmatch, ES Media Player, Player Music años other with headphone Grado the audio level is low
I have ZenFone 4 Pro and ZenFone 2, the problem is with ZenFone 4 Pro, I think that last update (firmware) is the problem. I startup in safe mode and ZenFone 4 keep the audio level low.
Falcon_ASUS
euro_pe
  1. Model Name: Z01GD
  2. Firmware Version: WW_ZS551KL_15.0410.1911.117_0
  3. Rooted or not: NO
  4. Frequency of Occurrence: with lata update
  6. Neutron app level sound is good with headphone Grado.
  7. PowerAmp, VLC, PlayerPro, WavePad, Musixmatch, ES Media Player, Player Music años other with headphone Grado the audio level is low
@euro_pe
ZS551KL has not been updated for a long time. If the situation remains the same in safe mode, according to what you described, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/ Sorry for any inconvenience it may be caused.
euro_pe
A question, Can I downgrade to other old firmware, like firmware of 2018?. I download olds firmware.
Falcon_ASUS
euro_pe
@euro_pe
Sorry, you need to enter the engineering mode to flash the firmware, so you may not be able to operate it yourself.
