rog phone 2 battery drain
- Model Name:rog phone 2
- Firmware Version:17.0240.2103.75
- Rooted or not:no
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
my phone battery drain very quickly like 10% in 25 min with light browsing and youtube. this probably started 1 month ago.
0
Comments
This is mine phone...........
Can you share your settings & battery health %
I'd recommend you to backup and factory reset your device as you obviously have an app that's draining your battery. If you still experience similar battery life after the factory reset, then there might be something wrong with your battery.
Check these settings I hvnt done anything just after update I reset my phone do hard reset but before that create backup in usb pendrive if necessary
Usually Social Media apps are the big culprit because they want information from and about you. I would start from there and work way through your phone which apps take information about you.
Turn off any unnecessary features of an app where you don't need them.
