Charging Problem For Asus Rog Phone 3
1.) Rog Phone 3,
2.) 17.0823.2012.122,
3.) Non Root,
Sir, I dont know that's a bug or not..A Few day I Plugled My Phone for Charging more than 2hrs.but its increase only 60 percentage 15 to 73 (Slow Charging option also Enabled)
0
Comments
Wrong forum.
ROG Phone 3 — ZenTalk (asus.com)
Hi shyamgopi007,
If you have enabled the slow charging it will take time to charge the device at a slower rate.
Can you disable slow charging and let me know the amount of time taken from 0 to 100%?
1.30 Minutes sir, I have another doubt In Lock screen the Refresh Rate Was Changed Higher Automatically more than 90Hrtz, Then I Unlocked My Device It was automatically Change 60Hrtz. Its Affect Battery Life ?
