Software bug with sound though bluetooth headphones on ZenFone 7 pro
It seems that when I connect my Sennheiser headset to the phone and listen to music, if i receive an audio notification or scroll through Instagram and view a autoplay video, either while listening scroll through gallery and I have a recorded video it will override the audio rendering and play sound trough both bluetooth and phone speaker at once without an displayed error, the only way to overcome the issue is to restart the phone
Comments
I don't have that problem using TaoTronics TWS earbuds
I will try with different headsets and see if it happens again
Did a new test, hence my issue was using Poweramp with Sennheiser headset. It seems the issue occurs if a setting in Poweramp called direct control dvc is ticked on, once that feature is off I can receive notification or view a video freely returning to headset audio rendering as it should do
Thanks for coming back and letting us know how you solved it. It'll be handy for other users that may encounter the same problem using PowerAmp and BT headsets.
