Issue with ringtone and notification sound on bluetooth headphones
user4292
When I have bluetooth headphones (two different models) connected with the phone then ringtone and notification sound is still played from internal speakers and on headphones it is played with very low volume at the same time. The expected behaviour is that it should only be played on headphones with correct volume.
Issue is present on Asus ZenFone 10 with latest fw version (WW_34.1004.0204.128) installed, but it was also present on previous fw versions.
Mansi_ASUS
Hey @user4292,
Could you please share a Bluetooth log?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Bluetooth”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Hey @Mansi_ASUS , I've sent you private message with the logs. Thx.
