Info about max temperature
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
What is the maximum temperature to not exceed in order to not damage the phone components while playing games?
I usually stay on an average of 41/40 degrees while playing Pubg...it will damage the phone if the temperature is this for about 2/3 hours?
Comments
Since the heat leaves the phone you'll be fine,I played 5 hours on overclocked performance and on 51 degrees,it will not damage your phone or your battery,if your charge it tho,then the battery will have a bit of a problem in the long run so focus on the way you are charging instead of the temperature of the phone
Btw I play 90 FPS ultra HD with water reflections on 47 and there is no throttling so it's fine
No offense but i smell BS on your statement. There is no 90 fps option on ultra HD, especially with water reflections enabled.
Maybe he is using 3rd part software to enable it
Ok Thanks
Hex editor
Then explain my BS right here
If you know what you are doing,and use the right 3rd party apps,you can manually change the fps through its files,it's a No ban solution for the best quality pubg mobile experience on a device
