Asus zenfone max pro m2 call issues
Please tell us some basic information before asking for help:Asus zenfone max pro m2 has call issues without turning on loud speaker i can't speak calls...its so irritating...
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
0
Comments
Hi, kindly help us with the following information to find a solution to your query.
1. Firmware version your device is on.
2. Elaborate more on your concern.
I guess this is software issue or bugs in firm ware update provided by company, even in M1 I have same issue. Try to reset ur device if this is for first time & check it.
same here, Have been facing it since pie update I reported several times but Asus did not fix it in any updates.
This is the primary issue that should be fixed first and make usable phone
I dnt think they will now fix anything on Pro devices as they are older now.
