Very very loud Noise on receiver while on call & can breach call confidentiality for other people
AJ1
Rising Star II
Model Name: Max Pro M1
Firmware Version: .087
Rooted or not: NA
Frequency of Occurrence: Regularly
When I'm speaking on outgoing call or incoming call, the 2nd party's voice is almost loud as the voice which we can hear / listen from speaker. It is like Dolby Bass voice very loud even I checked it by reducing call volume to 0, but nothing happened. I checked via wearing earphones as well nothing happened. I need to keep phone / earphones away from my body while talking. One more I noticed is that if I'm 1-5 Mtrs approx from my phone, even I or any other person can hear that noise from such distance & can know what discussion is going on a call. this is without turning on Speaker, Only incoming voice from receiver.
How to reduce the volume & change it to default normal sound getting from receiver as it is difficult to have a call as anyone can listen any confidential things going on call.
Yachendra
Rising Star II
AJ1
  1. Model Name: Max Pro M1
  2. Firmware Version: .087
  3. Rooted or not: NA
  4. Frequency of Occurrence: Regularly
My device's receiver sound is normal and doesn't have such an issue as you are facing.
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
AJ1
Rising Star II
victor2020
Is there any solution other than resetting the device
