Very very loud Noise on receiver while on call & can breach call confidentiality for other people
- Model Name: Max Pro M1
- Firmware Version: .087
- Rooted or not: NA
- Frequency of Occurrence: Regularly
- APP Name & APP Version (If your issue relates to the app):
When I'm speaking on outgoing call or incoming call, the 2nd party's voice is almost loud as the voice which we can hear / listen from speaker. It is like Dolby Bass voice very loud even I checked it by reducing call volume to 0, but nothing happened. I checked via wearing earphones as well nothing happened. I need to keep phone / earphones away from my body while talking. One more I noticed is that if I'm 1-5 Mtrs approx from my phone, even I or any other person can hear that noise from such distance & can know what discussion is going on a call. this is without turning on Speaker, Only incoming voice from receiver.
How to reduce the volume & change it to default normal sound getting from receiver as it is difficult to have a call as anyone can listen any confidential things going on call.
Comments
My device's receiver sound is normal and doesn't have such an issue as you are facing.
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
Is there any solution other than resetting the device
