Max Pro M2 428 firmware
Installed the 428 firmware. The annoying settings suggestion is still there in the settings app that you can't discard. "Add fingerprint to unlock" and after some time it will stack up more. That is the quality of Asus.
0
Comments
Hi there, the same cannot be removed as it is a UI Default by Android. Thank you.
Can we install beta 4 directly from beta 2 ( Max pro M1)
You will add a fingerprint and then delete. The offer should disappear.
I have several nokia phones and not one of them has this issue
What a pathetic excuse to hide the incompetence of the developers
I have the same issue...they are not solved the issue..its already mentioned the previous beta 2 update. But developers not fixed it.
Asus developers are incompetent, do yourself a favor and next time don't buy an Asus phone
I also have rhe same problem... Just tell me one stock android phone that shows like this. After accepting all the suggestions the option will disappear but in this case one option suggestions doesn't disappear
Because they are not using latest build of AOSP
I have questions regarding dataloss in this update
Tell me that your data was lose or not after update
Sorry my English is not that strong so avoid some mistakes
If u update from 087 be prepared for formatting.. backup before updating
I had this weird problem since the last beta 2 of max pro m2. My Oneplus bullets wireless 2 sounds like they have lost all bass and have no depth to the sound. This happened in this update also. Pls help as they sound fine on other mobiles i connect to
I have 097 latest sept security update
Bro try asus dolby Equalizer (i hope that will work)
【Google play music recommended】
Search on YouTube asus Dolby for max pro m2 no root and then download that apk
Sorry but i can't post link
I tried installing dolby but the app just wont open. And everything was fine in Android 9. I had to downgrade the system from Android 10 for only that issue. The earphones connect all fine with qualcomm aptx hd running. I tried reconnecting, forget the earphones and pairing again but did not work out. Is this problem due to the fact that oneplus bullets 2 have dual drivers ?
