Idle battery draining problem ( max pro m1 .87 firmware)
- Model Name: Zenfone max pro m1
- Firmware Version: .87
- Rooted or not: No
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
I am facing severe idle battery draining problem in my max pro m1. It is a brand new phone that i have purchased one month before. So i dont think it is much of a damaged battery problem. Yesterday night the battery had drained a whooping 49 percent in screen off and the phone have been in deep sleep only for almost 2 hrs since 11 hrs from the previous charge. Screenshots attached below
I brought this phone since i want to boycott chinese mobiles and I loved stock android but I have to admit that my 3000 mah old redmi device has better battery than this 😞. Now I dont care whether it is stock android or ZenUi, dont care whether i have the latest security patch or android version but please asus provide a software that gives good battery backup and can be used as daily driver. (Nb: As this is my new phone, I've to manage to use this atleast for 2 years 🙏) Please hear my request.
Comments
Please do factory reset and after factory reset you screen on time would definitely nearly 9-10 hrs my mobile works
Do a battery calibration by following the instructions below
1. Discharge your phone fully until it turns itself off.
2. Plug your phone into a charger and, without turning it on, let it charge until the on-screen or LED indicator says 100 percent.
3. Unplug your charger.
4. Turn your phone on.
See if the battery life has improved or not
Buy new phone permanent solution
Do what people suggest, if it's not any better, you should go to repair service because your battery is in bad condition.
The phone was bought 1 month before.
And to damage battery I haven't done any excessive charging. Only charge 1 time a day usually.
Lot of phones come faulty from factory, why are you surprised.
I had same issue but when o visited service center they resolved this, it's better if u visit to SC
Ok thank you everyone for your suggestions
I installed greenify app & now I'm getting better battery backup. So I guess it was an issue of app running in background even in sleep mode. Asus please get better battery optimization in the future updates.
Very bad battery backup in idle and screen on mode very disappointed..of this 087 update...
082 is the good from this .. update
Hi, please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
you may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
