Frequent wifi disconnection Issue On Max Pro M2
Even though this (2019) 15 thousand ruppees phone does not have a 5ghz wifi band which is really embarassing, we are left with a 2.4 ghz band which has poor reception and is frequently disconnecting from the wifi network even in good reception area.
I am on A9 latest build and Hope this is a software issue and will be fixed in the upcoming updates.
Comments
It is not a software issue and cannot be solved by a software update.
Hey have you tried with a different WiFi connection?
Also, there is a new update today
https://zentalk.asus.com/en/discussion/35215/200828-zenfone-max-pro-m2-zb630kl-in-16-2017-2009-97#latest
Do let me know if this fixes.
