ROG Phone 2 AURA RGB LED Logo Not Working! Please Help!
My RGB Logo was working an hour ago, now it isn't working, I am on the latest WW version, restart didn't work. Please help.
0
Comments
Do you have System Lighting?
Swipe down from the top and with all the icons you see, go through it until you see System Lighting. Ensure this is turned on.
Of course I do!
Go to SMMI test by .12345+ in calculator, scroll down and find the Aura system lighting in manual test. Turn on the system lighting and then test the lighting. If Rear RGB flashlight starts and logo didn't then it's an hardware issue. In that case please visit Asus service center.
Did that, the only thing lighting up is the light thats near the flash, not the RGB Logo, but its strange, it was working an hour ago!
It does just that RGB flashlight, not the logo.
This phone isnt selled in my country, and i dont have warranty.
It happened on my rog 2 initially. Put in original aero case or press the backside bottom part, the aura light will turn on. Its the loose contact of led due to back glass cover loose.
Try and let me know. I thought I'm the only one but recently this issue is fixed automatically due to phone heating, back glass cover got tight.
Oh my gosh dude, yea, its loose contact!! What should I do to fix it then?
