Pubg lags when battery is below 10% on Max Pro M2
In android 9 Pie When the phone's battery hits 10% Pubg starts lagging so much that the game is almost unplayable. Anyone else having this issue?
0
Comments
This is not an issue, this is a feature of android,
when the battery is under 10 percent, android throttle's the processor down so the battery can last longer.
Is it only for Stock android? Because my teammates play On Motorola's and Realme's and they dont see any difference in performance in pubg or any foreground applications when low on battery.
Does your phone switch to battery saving mode under %10? Battery saver mode decreases performance slightly when active, make sure you're not in battery saving mode when playing games.
Normally below 15% phone will always went to battery saver mode and battery saver mode decreases performance so while playing games makes sure that u should turn off your battery saver mode.
Thanks!
It lags even when the battery saver is off.
This is not happening because of battery saver.
Every android phone throttle down their processor when the battery is below 10 percent to extend the battery life.
Hi there, kindly share with us the firmware version of your device, also elaborate if the lag happens only during PUBG or other applications get affected too.
Firmware Version WW-16.2017.2005.092
The problem exists in every other heavy game.
