Battery draining overnight issue
- Model Name: Max pro M1
- Firmware Version: Android 8.1.0, Feb 2019 security patch
- Rooted or not: No
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
I just brought a new zenfone max pro m1. For a week battery was going fine. But today it had drained 10 percent overnight while the phone was idle. I did not installed any apps recently. The device is running android 8.1.0 feb 2019 security patch that came preinstalled. I haven't updated it yet. Please help me. And which firmware till now is the most stable one without any bugs & battery draining. Please reply 🙏
0
Comments
I also have this problem for a month now 55% of battery is drained overnight.
I also experienced the same problem, but haven't found a solution
Isn't this a software issue?
Hi there, kindly help us with the following information to find a solution to your query.
i. Charge the battery to 100% & use as per your normal usage pattern
ii. When the battery strength reaches 10%, go to settings = Battery => Tap on the battery icon & share the graph
iii. settings => Battery => Check the screen & share the same
Also, please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
I have also facing 15-20 % battery drain overnight tho' phone is idle ,
the firmaware version is Android 9 June-20 patch
Followed the guidelines charged to 100% & rest idle for overnight, found in the morning battery at 83%.
Checked for battery usage found no apps.
So How can battery drains 17% overnight though phone is idle.
Can you tell your build Number from Settings/System/Build Number at bottom ?
Check OTA update
Update it
#Report the build Number
Check for battery drain again after 1 FULL session of 0-100 charge 100-0 discharge and charge 0to100 and then check for drain from 100 to0.
#Report here.
Screen shot After charging battery to 100% , battery position after daily normal use.
Do this again in safe mode.
To boot to safe mode. Long press power key and long press restart.
Use in that mode from 100 to 0.
And report. May help in identifying any culprit apps or if problem is in system.
Speaker and sound quality is so bad please fixed it
Recalibrate your battery.
To recalibrate:-
1- Charge your battery to 100%
2- Then drain your battery to 0%( Till it gets switch off)
3- Then again charge your battery to 100%( In switch off mode)
4- After 100% switch on the phone and when the Asus logo appers plug out the charger.
If still your battery drain Issue doesn't solve then kindly visit to your nearest Asus service center for better solution.
Thanks!
Attached screenshot of built number as requested -
Use phone in safe mode for 1session if 100 to 0.
Will help in identifying draining apps.
Buld number screen shot attached
Hide imei. Delete screenshot. V82 understood.
Try this too.
Not understand what you want to suggest..
Pls clarify..
Delete the screenshots. Do not show your imei publicly.
And use phone in safe mode for one session from 100 to 0. And post battery results.
Not able to delete.
How can I remove ?
