Battery draining overnight issue
vishnusdz013
Model Name: Max pro M1
Firmware Version: Android 8.1.0, Feb 2019 security patch
Rooted or not: No
Frequency of Occurrence:
I just brought a new zenfone max pro m1. For a week battery was going fine. But today it had drained 10 percent overnight while the phone was idle. I did not installed any apps recently. The device is running android 8.1.0 feb 2019 security patch that came preinstalled. I haven't updated it yet. Please help me. And which firmware till now is the most stable one without any bugs & battery draining. Please reply 🙏
41 REPLIES 41
RadeonPS
Rising Star II
yaminimahajan21
https://zentalk.asus.com/en/discussion/comment/95229#Comment_95229
Screen shot After charging battery to 100% , battery position after daily normal use.
Do this again in safe mode.
To boot to safe mode. Long press power key and long press restart.
Use in that mode from 100 to 0.
And report. May help in identifying any culprit apps or if problem is in system.
usakiyem
Rising Star I
Speaker and sound quality is so bad please fixed it
Debasish_Sahoo
Zen Master I
Recalibrate your battery.
To recalibrate:-
1- Charge your battery to 100%
2- Then drain your battery to 0%( Till it gets switch off)
3- Then again charge your battery to 100%( In switch off mode)
4- After 100% switch on the phone and when the Asus logo appers plug out the charger.
If still your battery drain Issue doesn't solve then kindly visit to your nearest Asus service center for better solution.
Thanks!
Anandu
Can you tell your build Number from Settings/System/Build Number at bottom ?
Attached screenshot of built number as requested -
RadeonPS
Rising Star II
yaminimahajan21
https://zentalk.asus.com/en/discussion/comment/95239#Comment_95239
Use phone in safe mode for 1session if 100 to 0.
Will help in identifying draining apps.
