Battery problem
mpcampano_75
My phone's battery become slightly enlarged i dont know if it is overcharging but it affected my phone badly. My battery drops fast and when you open it while its low bat it will shot 50% but it will die minutes later. It also became laggy when it hit the 50% charge percentage.
Model: zenfone max pro m1
7 REPLIES 7
veeharish2005
Zen Master I
mpcampano_75
Battery problem
Do a battery calibration by doing the steps below.
Discharge your phone fully until it turns itself off.
Turn it on again and let it turn itself off.
Plug your phone into a charger and, without turning it on, let it charge until the on-screen or LED indicator says 100 percent.
Unplug your charger.
Turn your phone on.
And about the battery bulge , there are a lot of factors which can cause battery bulge .it can be caused by over charging, amount of charging cycle's of the device, amount of discharge,etc.
mpcampano_75
veeharish2005
https://zentalk.asus.com/en/discussion/31028/battery-problem
  1. Discharge your phone fully until it turns itself off.
  2. Turn it on again and let it turn itself off.
  3. Plug your phone into a charger and, without turning it on, let it charge until the on-screen or LED indicator says 100 percent.
  4. Unplug your charger.
  5. Turn your phone on.
I already did the battery calibration 1 time. Thanks for the info i will try to do it again
Christine_ASUS
Community Legend II
Hi mpcampano_75
Thank you for your asking. Based on your description, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/
If it is impossible to access the service center during Covid-19 period, please try Call us: https://www.asus.com/support/CallUs
abhaykrishnan02
Zen Master I
veeharish2005
now a days phone does not doesn't overcharge after 90% they go for trickle charging
