In ASUS MAX PRO M2, call recording facility is not given, also third party apps do not work.
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Best Answers
BlueHunt Level 3
In stock android, Google doesn't allow two apps to access the mic at the same time. Its Google's GMS policiy. Thats why when you call someone or attend someone's call, that time, only the Phone app will access the mic and no other apps such as call recorder apps can't be able to access the microphone. Thats why call recording is not possible on Stock Android devices.
1 -
BlueHunt Level 3
Since the limitations I have mentioned above set by Google for stock android platform, there's a provision in Android 10 and above where 3rd party apps could be able to access the mic but users need to provide permission. 3rd party apps need to update themselves accordingly. We can only tell that after getting updated to the Android 10. But still, if Google keeps its restrictions for third party apps for not to access the mic during phone calls are going on, then in stock android phones, we cannot use any 3rd party apps to record calls.
1
Comments
Thank you for your quick response. Further I wanted to know what should I do technically to make possible call recording in ASUS MAX PRO M2 phone.
Thank you once again...
You are most welcome. Happy to help.
I recently updated my max pro m2 to beta version of android 10. After the update i notice the change in volume of loudspeaker. The volume has noticeably decreased even though I keep maximum volume in settings. What is the issue?
I recently updated my max pro m2 to beta version of android 10. After the update i notice the change in volume of incoming ringtone alarm tone. The volume has noticeably decreased even though I keep maximum volume in settings. What is the issue?
