Extreme Battery Drain after A10 update
So, as many noticed, after Android 10 update also my battery is draining extremely fast. It seems it's because the CPU#8 is stuck at 100%. Is someone from Asus aware of that? Is someone working on a solution? It's not just my problem. But the funny thing is that some users that are still with Android 9 are experiencing the same issues.
0
Comments
Yes! My battery life is horrible since the android 10 update!
Same thing here. I went from being able to go 2 days in a row easily before having to recharge to less than 8 hours before having to recharge. WTF Asus? All since upgrading to Android 10
Can you check for Facebook app updates? There have been many reports of huge drains and they have almost all been caused by Facebook, which also seems to have been addressed with their latest app updates.
Yes I solved it many days ago by uninstalling Facebook. After reinstalling 3 days later was already solved. I forgot to reply here.
I don't have facebook app, but I've also noticed battery drain issue. 80→10% in around 12 hours, without playing any games.
Please don't consider last half hour data as I plugged in at 11%.
Do I need to say anything more.
Earlier i thought it could be a problem with deep sleep, but it seems fine.
