Fast charging problem.
ranathpodem
Not charging fastly. When I tried with another cable it works fast charging and then I connected with Asus regular cable it works after using other cable but it not working if I connect Asus cable firstly. Is it a software bug or cable problem?
asifbarwatiya
Rising Star II
Bro same here!!!
Anders_ASUS
Hall of Fame III
ranathpodem
Sounds like a coincidence that it was because you used cable A first and then cable B but I'm looking into now if there's some bug that causes random speed charging since several users started to complain at the same time.
