Zenfone 10 wireless charging
mokaldo1
Ive been using wireless charging almost exclusively since I got my zenfone. Recently it has been inconsistent and sometimes doesnt work. the phone vibrates and shows the charge like the charging has started, but doesn't show the status bar icon. It seemed like it stopped for a day or so then started again and now a week later is doing it again. Has anyone else had this problem?
Mattias_ASUS
Hello @mokaldo1
I haven't heard about this before, but I would like the dev team to take a look at it, would it be possible for you to create a log for the team to look at?
Also, does the phone charge normally if you use a cable? And are you on the latest firmware 35.0604.0404.131?
To make one you can follow the instructions down below.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Charge” will work for this.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
