transferring applications to MicroSD card Android 9
YeLRaW
Model Name: Zenfone MAX SHOT ZB634KL
Firmware Version: WW_Phone-16.14.2002.291_20200121
Rooted or not: not
Frequency of Occurrence:
I would like to know why the zenfone max shot does not allow the transfer of applications to the Android 9 micro SD card
observation I already activated the option to force move applications under development
it still didn't work
I believe it is something from Android 9 or ASUS itself that does not allow it.
6 REPLIES 6
Y_ASUS
Zen Master I
Hi YeLRaW,
Apps to SD card feature isn't available now.
Thanks for your understanding.
YeLRaW
YeLRaW
https://zentalk.asus.com/en/discussion/comment/70418#Comment_70418
I also think that Android 9 does not allow to move applications to the microsd card unfortunately thank you.
whoever has a solution and welcome
is it an option that ASUS removed or was it Android that it removed ?
