Incoming call notification does not show on screen. I'm using Asus ZenFone Max M2.
abhayphan
Model Name: ASUS_X01AD
Firmware Version: Android 9, Security Patch Level 5th March 2020
Rooted or not: Not rooted
Frequency of Occurrence: Always
APP Name & APP Version (If your issue relates to the app): Android systen app
I can not see incoming call notification screen where I can receive the call or reject.
Every time when there is an incoming call, I have to unlock the screen and pull down the notifications and receive the call from there. It's very annoying. I have updated system software but the problem is not resolved. Please help.
Thanks
victor010
Zen Master III
Hi there, you may click on the following link to download the latest update manually, request you to read the instructions before upgrading and take a full backup of the device before. Click here: https://www.asus.com/in/Phone/Zenfone-Max-M2-ZB632KL/HelpDesk_BIOS/
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
