Battery usage
h_pourhabiby
battery usage is not work correctly in zenfone 3 max andoid 8.1
ServiceE_Asus
Hi h.pourhabiby, Good day, Please kindly restore the mobile manager app and reboot the device to a check. (settings > apps & notifications > see all apps> app info> mobile manager> storage & memory >clear data and cache.) If this problem still appears, please kindly tell me your firmware version and error screenshot. (settings> system > about phone > software information) Thank you.
h_pourhabiby
thanks you so much problem solved
h_pourhabiby
My software system version is 15.0200.1812.503-0 Is it last version of my system software for zenfone 3 max? my problem not solved
