Android 10 update
Zeeshan_Ali_War
Hi
I wanted to ask whether my asus zenfone max m1 (ZB556KL) would get android 10 or not٫ when
1 ACCEPTED SOLUTION
Accepted Solutions
Saurabhw
zeeshanaliwaris
I do have some issues,like it has sone bugs.Sometimes,the status bar disappears suddenly ,otg is not read successfully everytime,and some other minir issues that effect the appearance.As I had checked on the internet it shows Max m1(ZB556KL)-is likely to get android 10,so want to confirm it.
Android 10 beta AOSP build is available FOR ZB556KL.
7 REPLIES 7
RadeonPS
Rising Star II
zeeshanaliwaris
Hi
Android 10 update
Max pro m1 will receive android 10 by april end or mid may. U can use beta if u want but do read description fully.
ARP_ASUS
Community Legend II
For the best hardware & Software experience, Asus Max M1 is limited to the current update. If you are facing any particular issue with the said version do let us know.
Zeeshan_Ali_War
ZT-0226f461
When Max Pro M2 will get Android 10 update? Now, its getting too late to get into latest android update. Please announce a tentative release date for Zenfone Max Pro M2.
