Android 10 Bugs Of Asus Zenfone Max M2 ( zb632kl )
Luvgya
Rising Star I
Model Name: Asus Zenfone Max M2
Firmware Version: OPM1.WW_Phone-17.2018.2002.29-20200409
Rooted or not: Not Rooted
Frequency of Occurrence: Every Time
APP Name & APP Version (If your issue relates to the app): Stock Camera App Is Not Working Well
87 REPLIES 87
Pritam_verma
Luvgya
https://zentalk.asus.com/en/discussion/comment/75014#Comment_75014
Have You Tried The Video Recording . If Tried Then Howz Ur Experience
Very bad experience bro I have facing a video recording lag and noise reduction not work it's only for show off .
Pritam_verma
praveenrawat2499
https://zentalk.asus.com/en/discussion/comment/75015#Comment_75015
Unable to reset my phone,its showing "no command" always
Yes bro it's true .
Pritam_verma
deadPOOl
Anyone experiencing otg not working it is only showing reverse charging whenever i plug my otg android 10 beta same prob with stock cam though Gcam is working properly for me
Yes bro it's true.camera2api enable but gcam cannot support Asus please fix this bug
Pritam_verma
Luvgya
https://zentalk.asus.com/en/discussion/comment/74780#Comment_74780
Just hard reset your phone
Follow tutorials to hard reset from youtube by searching how to hard reset android phone
But bro hard reset means wipe data factory reset options not available on recovery mode
Luvgya
Rising Star I
Pritam verma
https://zentalk.asus.com/en/discussion/comment/74782#Comment_74782
When it is showing no command then you have to press volume up and power button at the same time . Then it will go to recovery mode .
Do Not Long Press Them When It Is Showing No Command Just Press Both At The Same Time
