04-22-2020 08:51 PM
04-25-2020 09:41 PM
04-25-2020 09:44 PM
umangsharma9199Please upload some stock camera app screenshot after Android 10 UPDATE
04-25-2020 09:45 PM
praveenrawat2499You Need To Hard Reset Your Phone Before Update To This Softwarewhy u had not mentioned properly that its a Beta version???? Lots of bug
1- update install krte hi pin manga ,pin accept nhi hua or phone reset karna pda. So i lost my data 🙃
2- battery drainage
3- serious charging problem, taking 5- 6 hrs or more for full charge
4- some app's are not performing well
5- low sound quality
6- stock camera quality,UI or kharab hogya but nothing changed in camera
7- cant install gcam after update
8- cant install other apps
Many other bugs and errors.
04-25-2020 09:48 PM
Wahid708Have You Tried The Video Recording . If Tried Then Howz Ur Experiencehttps://zentalk.asus.com/en/discussion/comment/74360#Comment_74360
The picture quality is same
04-25-2020 09:48 PM
praveenrawat2499Your phone is damagedwhy u had not mentioned properly that its a Beta version???? Lots of bug
2- battery drainage
