- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-24-2020 02:22 AM
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-21-2021 11:33 PM
When will the fix on Asus Android 10 happen?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-22-2021 12:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2021 01:06 AM
Solution to the problem in Turkey while waiting for emergency calls, the Asus Turkey removed all versions on the Web site about Android 10, what is the reason?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2021 01:56 AM
Christine_ASUSmadharchod provide stable version nhi toh tumhari chod denge bsdke pele jaoge nhi toh dhang se kamm kro😂To avoid any emergency case, please downgrade to Android 9 in this moment. Sorry for any inconvenience it may be caused. You may follow the steps below as 10 to 9 downgrade steps.
1. Download "Version MaxProM1_downgrade_to_9" and then put the image file into the root directory of the MicroSD card.
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
2. Insert MicroSD card into phone and then power off the device.
3. Long press with "Power" key and "Volume Down" key together and stop after feel the vibration to enter Recovery Mode
4. Use "Volume Down/Up" key and press "Power" key to choose "Apply update from external storage"
5. Select the downgrade file
6. When the updating process is done, Choose "Wipe data/factory reset" and tap"Yes" to perform the master clear.
7. "Wipe cache partition" > "Yes"
8. "Reboot system now"
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-16-2021 06:11 PM
Sorry for the belated reply due to Lunar New Year holidays.
As I mentioned above, if you encounter ZenFone Max Pro M1 (ZB602KL) Android 10 AOSP developer version will call to 112 while dialing 155/156/158/110/177 in Turkey, for Turkish users, please visit ASUS support site to modify your version to Android 9.
https://www.asus.com/tr/Phone/ZenFone-Max-Pro-ZB602KL/HelpDesk_BIOS/
We apologize for any inconvenience caused and your consideration will be very much appreciated.
Thank you for your continued support and patronage.
