- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-24-2020 02:22 AM
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-30-2020 10:44 PM
Christine_ASUSI had interviews I've done with the correction Asus Android 9 in Turkey service. Instead of excluding Turkish users, I expect you to fix on android 10. This is a software security error made by your company, you should fix it in android 10 as soon as possible. Recommending installing on Android 9 is not the solution.Dear Customer,
If you encounter ZenFone Max Pro M1 (ZB602KL) Android 10 AOSP developer version will call to 112 while dialing 155/156/158/110/177 in Turkey, for Turkish users, please visit ASUS support site to modify your version to Android 9.
https://www.asus.com/tr/Phone/ZenFone-Max-Pro-ZB602KL/HelpDesk_BIOS/
We apologize for any inconvenience caused and your consideration will be very much appreciated.
Thank you for your continued support and patronage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-30-2020 10:59 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-08-2021 12:01 PM
Will Turkey be corrected Android 10 emergency call problem?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-10-2021 07:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-14-2021 09:34 AM
Christine_ASUSWill there be no fix on Android 10? Don't we, as Turkish users, have the right to use Android 10? Why don't you do the fix?Hi,
