ZenFone Max Pro M1 Android 10 beta Emergency calls problem in Turkey.
cengizhankirac
Zenfone max pro m1 emergency call problem was corrected in Turkey. There was a problem on Android 10 too, is this problem fixed on Android 10? Android 10 must be checked before the final version is released.
25 REPLIES 25
cengizhankirac
Hello chrstine_Asus
When will the fix on Asus Android 10 happen?
qromodynmc
Rising Star II
I guess never, they started saying there will be no update or maintenance for devices older than 18 month. It's super silly how they caused problems then they refuse to fix it.
cengizhankirac
Hello Christine_ASUS,
Solution to the problem in Turkey while waiting for emergency calls, the Asus Turkey removed all versions on the Web site about Android 10, what is the reason?
Satnam
Rising Star II
Christine_ASUS
Hi cengizhankirac
To avoid any emergency case, please downgrade to Android 9 in this moment. Sorry for any inconvenience it may be caused. You may follow the steps below as 10 to 9 downgrade steps.
1. Download "Version MaxProM1_downgrade_to_9" and then put the image file into the root directory of the MicroSD card.
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
2. Insert MicroSD card into phone and then power off the device.
3. Long press with "Power" key and "Volume Down" key together and stop after feel the vibration to enter Recovery Mode
4. Use "Volume Down/Up" key and press "Power" key to choose "Apply update from external storage"
5. Select the downgrade file
6. When the updating process is done, Choose "Wipe data/factory reset" and tap"Yes" to perform the master clear.
7. "Wipe cache partition" > "Yes"
8. "Reboot system now"
#Android 10 to Android 9 Guide
https://www.asus.com/support/FAQ/1042349
madharchod provide stable version nhi toh tumhari chod denge bsdke pele jaoge nhi toh dhang se kamm kro😂
Christine_ASUS
Community Legend II
Hi cengizhankirac
Sorry for the belated reply due to Lunar New Year holidays.
As I mentioned above, if you encounter ZenFone Max Pro M1 (ZB602KL) Android 10 AOSP developer version will call to 112 while dialing 155/156/158/110/177 in Turkey, for Turkish users, please visit ASUS support site to modify your version to Android 9.
https://www.asus.com/tr/Phone/ZenFone-Max-Pro-ZB602KL/HelpDesk_BIOS/
We apologize for any inconvenience caused and your consideration will be very much appreciated.
Thank you for your continued support and patronage.
