12-03-2020 03:00 AM
12-03-2020 05:20 AM
arjuncsk1996Use mi 10W fast charger,your device will charge rapidly from 0 to :hundred_points:%Version JP-17.2018.2007.428
The fast charging is not working charging capped at 850 mA takes 6 hours to charge fully.
After downgrading back to android 9 using downgrader firmware fast charging works again and charges at 1750-1880 mA also it shows charging rapidly at lockscreen instead of just charging.
A10 Beta Bugs
12-03-2020 11:46 AM
abhaykrishnan02Like I said the problem is in the firmware not my charger also mi 10 watt charger is same as asus OG charger both are 5v 2A chargers. No difference in charge speed but beware max pro m2 is not compatible with 15 watt quick chargers and may overheat the device and damage the batteryhttps://zentalk.asus.com/en/discussion/41161/a10-beta-bugs
12-03-2020 07:20 PM
12-04-2020 02:23 AM
arjuncsk1996yes I had the same problem, about 2 months ago but until now it hasn't worked as usual. btw I have the global version (WW) and the update via OTA is not available until nowVersion JP-17.2018.2007.428
ZenFone Max Pro Fast Charging stops working after updated Android 10 Beta
