WORST MOBILE BATTERY I HAVE NEVER SEEN THIS TYPE OF BATTERIES.SO WORST BRAND AND BATTERY POWER AND P
psaravanankarur
Don't buy asus brand mobiles
Model Name:max pro m1
Firmware Version:0.87
Rooted or not:not
Frequency of Occurrence:
I charged my mobile to100%and without doing anything I kept my phone and after morning when I wake up when I saw my mobile battery reduce to92% 8%percebtage decreased without any usage.worst battery plz don't buy asus brand mobiles.
victor010
Zen Master III
Hi, Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
5. Check the following article for more information: https://www.asus.com/in/support/article/604/
You may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
