Why I can't updated Android 10 by OTA in Max Pro M1?
nikuta
Model Name: Max Pro M1
Firmware Version: Version WW-17.2017.2006.429
Rooted or not:NO
Frequency of Occurrence:
Why I can't updated A10 - Version WW-17.2017.2006.429 to Version WW-17.2017.2008.432 by OTA (auto apdate) ?
Why I have to do it manual and reset all my settings again?
nidhin3
Zen Master I
WW-17.2017.2008.432 is beta 4 for Asus Zenfone max pro M1. That is the reason why you are not receiving the update via OTA. We will receive an OTA only when Asus releases a stable Android 10 build.
Remove PIN, Fingerprint and Face unlock feature and install the update manually. You will most probably not loose any data. I have done the same and all my data are safe.
Yachendra
Rising Star II
nikuta
  1. Model Name: Max Pro M1
  2. Firmware Version: Version WW-17.2017.2006.429
  3. Rooted or not:NO
  4. Frequency of Occurrence:
Because, Asus not released it as OTA.
amit_gore2
nikuta
  3. Rooted or not:NO
Your question will hurt asus. Take it back.
