06-27-2020
10:35 AM
- last edited on
01-16-2024
12:59 AM
by
ZenBot
07-13-2020 08:19 AM
07-13-2020 07:09 PM
shreerangmoreHi shreerangmore,
- Battery performance MORE THAN latest update of andriod pie may security patch... bt the backup of battery must be a bit more it lasts for 8 hours of normal use in android 10 beta 2. it should be atleast 10 hours, which should possibly last till end of the day....
- I have strong wifi bt several times it losses connectivity, for normal wifi range for eg; between 3 metres range.
- network reception should be strong, might be any of the services providers, the device must be capable of receiving better signals...
- Sound output Must be as better as andriod pie 9.
- system laggy processes, displayed in notification bar 2 to 3 seconds which is annoying , it happens for almost every app since updates from december patch of android 9........ also it is there now in andriod 10. please fix it.... ber IMAGE attached for reference -------->
07-13-2020 07:10 PM
shreerangmoreHi shreerangmore,This app is crashing all the time... Which i use very frequently... Plz fix in next update...
