Battery performance MORE THAN latest update of andriod pie may security patch... bt the backup of battery must be a bit more it lasts for 8 hours of normal use in android 10 beta 2. it should be atleast 10 hours, which should possibly last till end of the day....
I have strong wifi bt several times it losses connectivity, for normal wifi range for eg; between 3 metres range.
network reception should be strong, might be any of the services providers, the device must be capable of receiving better signals...
Sound output Must be as better as andriod pie 9.
system laggy processes, displayed in notification bar 2 to 3 seconds which is annoying , it happens for almost every app since updates from december patch of android 9........ also it is there now in andriod 10. please fix it.... ber IMAGE attached for reference -------->
