Wasteful Battery
ZF Model: ZB631KL
RAM: 4G
Firmware/APP Version: 16.2017.2002.073
Frequency of Occurrence: 100%
Rooted: No
APP Name: Battery
After the latest FOTA update. I feel the use of battery power is getting wasteful, I feel like all applications are running and the device is hot. Though all applications are closed and I only run 1 application only. Before the latest FOTA update, the battery can last 8-10 hours with the use of Social Media, Games, Youtube, etc. But after the update only lasts 5 hours, sometimes even then not until 5 hours. This happened not only on my device, but my friend's device also experienced the same thing. I hope the Asus can restore the device settings as before. Thank you
0 REPLIES 0
