10-19-2020 09:19 AM
10-19-2020 09:47 AM
abhaykrishnan021. Adaptive battery feature will not solve the issue you are experiencing because adaptive battery will only limit the processing power budget for the app you don't use often, it will not limit or clear a app from ram because doing that will make it impossible to use some features of the app.
there is no proper ram management in MPM2 (.097)
i have not used (multiple account ) app from last 3 days but this app was still running in the background,and i was facing battery drainage over problem from last week maybe because of this app
want { ADAPTIVE BATTERY } option
10-19-2020 10:43 AM
veeharish20052. I'm using two app cloner but the other app cloner never runs in backgroundhttps://zentalk.asus.com/en/discussion/38193/want-adaptive-battery-option
2. The app is designed to be running in the background, it is not a bug,
10-19-2020 10:59 AM
abhaykrishnan021. Do you use two different app cloners if yes then the app which is running in the background is designed to do that.https://zentalk.asus.com/en/discussion/comment/125706#Comment_125706
