07-12-2020 08:29 PM
07-28-2020 08:00 PM
Y_ASUSPlease try to understand. I am requesting you to see the screenshots properly. VOLTE icon which is showing on notification bar that is for Jio VOLTE. I've two sim cards on my phone (Vodafone and Jio), that's why I give you two screenshots. You can easily notice that Jio VOLTE is working properly but in Vodafone settings there is no option for enabling VOLTE. Here is the screenshot for single Vodafone sim, and look here VOLTE for Vodafone is not enabled and also no option for enabling VOLTE.https://zentalk.asus.com/en/discussion/comment/99659#Comment_99659
Hi souvikshaw4004 ,
I see that the VoLTE icon appears on the notification bar. That means VoLTE is enabled. 🙂
07-29-2020 01:59 AM
07-29-2020 02:27 AM
07-29-2020 07:47 AM
Y_ASUSYes dual VOLTE enabled on my phone, I put a another Jio sim there was VOLTE working on both of Jio Sim... And few months ago I had Jio and Airtel sim and there was also VOLTE worked for both sim. I hope you understand.Hi souvikshaw4004,
Sorry for the misunderstanding.
We've checked with relevant teams about this behavior.
In the meantime, could you check if VoLTE isn't available in both SIM slots?
Have you checked whether your plan comes with VoLTE? Thanks 🙂
07-29-2020 07:49 AM
Debasish SahooHey I'm already activate that few months ago, and when I put this same sim on another device (Realme 3 pro) there the VOLTE for Vodafone is working properly. I hope you also understand.You have to activate Vodafone volte and for that you have to send a mail to Vodafone regarding Volte activation then only you can enjoy volte services. I am using Zenfone 5z and this trick works for me 🙂
