Ui lagging in every 20-30 mins, dnd icon, battery % bug
Muttakin
ZF Model: ZB630KL
RAM: 4G
Firmware/APP Version: OPM1.WW_Phone- 15.2016.1901.186.20190121
Frequency of Occurrence: Every 20-30 mins
Rooted: No
APP Name:
Last edited by muttakinbiswas on 2019/1/29 03:09 UI lagging during phone using. It's very disturbing. It's like frame drop kinda thing happening in UI. Suddenly notification bar auto came down then few min touch doesn't work.. it's happening every time in 20- 30 mins. Any one facing? After first and 2nd update this thing happening. Not fixed in 3rd update Also battery percentage got little cut, dnd icon showing after of not fixed.
ServiceH_ASUS
Hi muttakinbiswas Good day For Ui lagging problem, If the issue is still not fix please backup phone date and factory reset. In order to exclude caused by software. Both battery percentage got little cut and dnd icon showing will fix in next FOTA Thank you:)
Muttakin
Last edited by muttakinbiswas on 2019/1/31 09:56 The UI lagging problem is not fixed. Btw thanks for the next fota details. Please release the pie update soon too. Maybe the UI not well optimized.
