*Sound Issue*Max pro M2 A10 V428 September Update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-24-2020 12:18 AM
I have updated my Max pro M2 to 17.2018.2007.428.
Bugs:
Low volume through speaker and earpiece while calling. (speaker compared to Pie)
Low volume through speaker while playing music.
No bass through earphones. (tried max pro m1 bug fix method, it improved sound quality. still bass is very low compared
to pie build).
mobile network icon is missing. (screenshot 1 below)
Huge chin (Navbar) with A10 gestures. (Screenshot 2 above)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-24-2020 08:14 PM
vamsiI have the same issue with my oneplus bullets wireless 2. @ASUSIndia pls help
Bugs:
- Low volume through speaker and earpiece while calling. (speaker compared to Pie)
- Low volume through speaker while playing music.
- No bass through earphones. (tried max pro m1 bug fix method, it improved sound quality. still bass is very low compared
- to pie build).
- mobile network icon is missing. (screenshot 1 below)
- Huge chin (Navbar) with A10 gestures. (Screenshot 2 above)
Max pro M2 A10 September Update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-25-2020 02:11 AM
Thank you all for your asking. I have forwarded the information of MPM2 sound issue to the relevant department. We will keep you updated and your consideration will be very much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-26-2020 03:39 AM
I also get thats bugs like Vamsi, and also can't use share fiture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-03-2020 04:53 PM
Christine_ASUSThank you dear @Christine_ASUS but please do something fast , as our experience of listening music is completely ruined after .428 update .Hi friends
You should rollout a small update which fix audio issue first then you can rollout the next update .
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-03-2020 10:05 PM
vamsiFor 1,2,3,4 uninstall icepower via adb
Bugs:
- to pie build).
For5 download system ui tuner from play store and enable network icon and uninstall when you are done with it.
For 6, if your display size is set at small then goto developer options and enter smallest width size as 410 or try around at increment/decrements of 5. From 390 to 420 at least . In one of them chin will be resolved.
Try setting display size is normal chin may go away.
