*Sound Issue*Max pro M2 A10 V428 September Update
I have updated my Max pro M2 to 17.2018.2007.428.
Bugs:
- Low volume through speaker and earpiece while calling. (speaker compared to Pie)
- Low volume through speaker while playing music.
- No bass through earphones. (tried max pro m1 bug fix method, it improved sound quality. still bass is very low compared
- to pie build).
- mobile network icon is missing. (screenshot 1 below)
- Huge chin (Navbar) with A10 gestures. (Screenshot 2 above)
5
Comments
Where do you get your phones ?? I'm fine, sound, icons ...
Umm.., from asus.
Well, it happened for me too in pie builds. Many were complaining about bugs but I didn't have any at that time. It's very interesting why only some are having issues.
I have factory reset my phone after installation too.
The miss alignment in android 9 was in the earlier builds of android pie, but it got fixed in a fota update.
Sound quality very low improvement and battery drain problem , battery adopted not here
I have the same issue with my oneplus bullets wireless 2. @ASUSIndia pls help
Hi friends
Thank you all for your asking. I have forwarded the information of MPM2 sound issue to the relevant department. We will keep you updated and your consideration will be very much appreciated.
Yes so do i,
I also get thats bugs like Vamsi, and also can't use share fiture
Thank you dear @Christine_ASUS but please do something fast , as our experience of listening music is completely ruined after .428 update .
You should rollout a small update which fix audio issue first then you can rollout the next update .
For 1,2,3,4 uninstall icepower via adb
For5 download system ui tuner from play store and enable network icon and uninstall when you are done with it.
For 6, if your display size is set at small then goto developer options and enter smallest width size as 410 or try around at increment/decrements of 5. From 390 to 420 at least . In one of them chin will be resolved.
Try setting display size is normal chin may go away.
Where is Icepower? I can't find it in the app list
Sound problem p
Hi friends
To preserve ZB630KL system performance and stability, we have no plan for further adjustments of audio settings. We apologize for any inconvenience caused and your consideration will be very much appreciated. Thank you for your continued support and patronage.
Aight imma change my phone to samsung then.. adios
Does asus pay their employees?
You mean to say that
(Low sound from earpiece and loudspeaker problems while calling) will be not fixed
No bass in earphone will be not fixed
wow, wow, wow 🤬🤬🤬🤬🤬
This was not expecting from Asus dev team. My request to Asus team that you must not compromise with audio related buggy issues. Also 'Audio bass' is an essential thing for listening music. You must provide the requirements of the customer. I have seen some smartphones companies before that, failing in software support directly effect the market and they also loose faith of the customer. Being a musician i strongly believe that if you ignore in fixing audio quality no people would like to support you forever. So, kindly don't ignore this issue that affects the FAITH between you and us.
I hope you better understand the Audiophiles.
Thank You🙂
Waiting for almost a year and this is what we got? Bruh they told us to be patience and this is the result... Now we know who's the best company right now.
