12-26-2020 12:22 AM
01-01-2021 08:45 AM
albertkesThe sound is loud, but it only amplifier the mids and highs, suppressing the bass.https://zentalk.asus.com/en/discussion/comment/142825#Comment_142825
JBL Bluetooth headphones - the sound is excellent. The sound is louder in the wired.
01-01-2021 08:49 AM
albertkesI did this now brother, it does improve sound output from bad to below average.Sound improvement on Android 10, WW-17.2018.2012.434 firmware
Option for Windows 10:
1. Install Minimal ADB and Fastboot. (I installed adb-setup-v1.5.2).
2. Go to: Settings - About phone - Find the build number and tap on it several times until you see: "now you are a developer."
3. We go: System -For developers - USB debugging - Turn on.
4. We connect the phone to the computer (without turning off the phone), a message will appear like: enable USB debugging - allow. Android Composite ADB Interface will appear in Device Manager.
5. Run PowerShell as administrator and enter the commands:
adb devices
adb shell pm list packages
adb shell pm disable-user --user 0 dk.icepower.icesound or, if you want to completely remove: adb shell pm uninstall -k --user 0 dk.icepower.icesound
6. After restarting the device and check the sound.
I managed to fix the sound.
01-03-2021 09:48 PM
01-04-2021 12:57 AM
largefield61I used Boult audio, Boat wireless earphones + JBL Flip 2 Speaker and even connected to a sound system through aux. The sound is crap in both Aux as well as Bluetooth. I'm on Max Pro M2 ( 438 )https://zentalk.asus.com/en/discussion/comment/142820#Comment_142820
When using bluetooth headphone no problem?
01-04-2021 03:04 AM
mauvin11Using boult audio myself, disabled icepower for better sound. No issues encountered due to disabling it . Dont know why asus is still clingning to it.https://zentalk.asus.com/en/discussion/comment/142825#Comment_142825
