Sound improvement on Android 10, WW-17.2018.2012.434 firmware
albertkes
Rising Star I
Option for Windows 10:
1. Install Minimal ADB and Fastboot. (I installed adb-setup-v1.5.2).
2. Go to: Settings - About phone - Find the build number and tap on it several times until you see: "now you are a developer."
3. We go: System -For developers - USB debugging - Turn on.
4. We connect the phone to the computer (without turning off the phone), a message will appear like: enable USB debugging - allow. Android Composite ADB Interface will appear in Device Manager.
5. Run PowerShell as administrator and enter the commands:
adb devices
adb shell pm list packages
adb shell pm disable-user --user 0 dk.icepower.icesound or, if you want to completely remove: adb shell pm uninstall -k --user 0 dk.icepower.icesound
6. After restarting the device and check the sound.
I managed to fix the sound.
34 REPLIES 34
abhaykrishnan02
Zen Master I
albertkes
adb devices
And what about low sound from earpiece and speaker while calling
albertkes
Rising Star I
abhaykrishnan02
https://zentalk.asus.com/en/discussion/42378/sound-improvement-on-android-10-ww-17-2018-2012-434-fir...
I have no problem with that. The bell yells loudly, and everything is perfectly audible during a conversation.
largefield61
albertkes
https://zentalk.asus.com/en/discussion/comment/142816#Comment_142816
When using bluetooth headphone no problem?
albertkes
Rising Star I
largefield61
https://zentalk.asus.com/en/discussion/comment/142820#Comment_142820
JBL Bluetooth headphones - the sound is excellent. The sound is louder in the wired.
