[Solved] How to downgrade ZenFone Max Pro m1 Android 10 Beta 4 to Oreo Android 8
proveerhaldar
Can I get android 10 beta 4 to Oreo in max pro m1 by sd card method. (Sdcard method– keep Oreo software in sd card without any folder, go to the recovery mode, select the select the software file and flash the file.
1 ACCEPTED SOLUTION
Accepted Solutions
Christine_ASUS
Community Legend II
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
No, downgrade file is different from OTA file. For ZB602KL, you can only downgrade from Android 10 to Android 9 with downgrade file Version MaxProM1_downgrade_to_9, yet you can not install OTA file with downgrade procedure and claim it as firmware downgrade. There is no downgrade file from Android 9 to Android 8.
19 REPLIES 19
Reliance
proveerhaldar
Can I get android 10 beta 4 to Oreo in max pro m1 by sd card method. (Sdcard method– keep Oreo software in sd card without any folder, go to the recovery mode, select the <apply update from external storage> select the software file and flash the file.
Max pro m1 android 10 beta 4 to Oreo
No,u have to reinstall os through pc
Rams
Please provide link for Last build of Android Oreo. Can I downgrade from Android Pie to Oreo with that build?
Christine_ASUS
Community Legend II
proveerhaldar
Rams
https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZB631KL/UL-ASUS_X00T-WW-15.2016.1902.340-user.zip
