12-01-2020 06:34 AM
12-01-2020 06:56 AM
SinghApps killing out memory, did u tried, ending apps & other stuffs, & checked, if same thing is happening, then this is a real bug which asus will take more time to fix, as current bugs in updates still not fixed.
See it Asus team carefully your Max Pro M1 device ram manage status I'm using 3gb ram varient and see it I'm on developer option and take screenshots because when I'm using my phone every apps are reload in background every apps like fb ,messanger,whatsapp, pdf viewer,every game,camera,call and message apps so I check my ram status so your phone have only 261mb free ram out of 3GB this your optimization very shame for you Asus this type of rubbish optimization.
I'm facing this issue on Android 10 version 432.
My purpose for showing this issue with you only that you fix this bugs in next stable update please..
FIXED RAM MANAGEMENT ISSUE IN 3GB RAM MODEL DEVICE PLEASE AS SOON AS POSSIBLE PLEASE 🙏🙏
Software bug in Max Pro M1 device
12-01-2020 08:27 AM
SinghU can use battery manager to restrict any app from running in background
12-02-2020 10:45 AM
SinghSadly the Google app just constantly uses huge Memory in background similar to OS,System and UI. Chrome doesn't have high average memory usage but it does have high max memory usage.
12-02-2020 10:47 AM
SinghIf you want to multi task with other apps more than disable Google app for the 3Gb model.
