Review of Asus ZM Pro m1 Android 10 beta 3(QKQ1.WW_Phone-17.2017.2006.429-20200614)
vaibhavbelhekar
Model Name: Asus ZM Pro m1
Firmware Version: (QKQ1.WW_Phone-17.2017.2006.429-20200614)
Rooted or not: no
Frequency of Occurrence:
I would like to thanks asus, for providing android 10 beta 3 for max pro m1. I had updated my device today morning and using it since 5 hrs. Belive me or not my experience is amazing. This beta 3 is very close to the stable update. Many bugs are fixed in this update.
1) very important, pubg can be run in hd graphics and high frame rates ( thank you asus)
2) pubg experience was very smooth. I had played in smooth+ high settings.
3) After 1hr of gaming my battery drain was only 14%. It was amazing, battery backup felt to be good.
4) Sound from speaker is very loud. Asus has done impressive work in terms of sound quality (thanks again).
5) I didn't notice any lagg after updating my device.
I think this update is close to the stable one. I will post my full review after using it properly.
Thank you Asus....
19 REPLIES 19
vaibhavbelhekar
Dev Kumar
Bad sound quality through earphones in android 10 beta 3
Neither bad nor good. Sound quality through earphones is very flat but the sound quality is ok for me. I do not use to listen music too much..
vaibhavbelhekar
saitejaakula
Being on beta 2, can we upgrade to beta 3?
sandeeppant7
Stable se update karne me data format ho jayega? Reply
rafaelbc92
vaibhavbelhekar400
  1. Model Name: Asus ZM Pro m1
  2. Firmware Version: (QKQ1.WW_Phone-17.2017.2006.429-20200614)
  3. Rooted or not: no
  4. Frequency of Occurrence:
Thank you Asus....
Olá, boa tarde!
Na tela do meu celular está aparecendo um pedido de atualização do sistema.
Lendo os comentários aqui, vi muitas pessoas desconfiada com essa atualização. Isso me gerou uma certa preocupação em atualizar e acabar não gostando por possíveis falhas dessa suposta nova atualização.
Gostaria de uma opinião clara e objetiva de alguém que entenda ou até mesmo da própria ASUS sobre essa nova atualização.
1 - É oficial e estável?
2 - Quais problemas posso ter com o consumo de memória e bateria?
3 - É recomendável atualizar agora ou devo esperar uma outra nova atualização? (Isso se tiver rs)
Vejo vocês falando sobre o termo "Beta" nos comentários e não entendo nada disso. Sou leigo no assunto.
Tenho medo de atualizar e acabar não gostando devido a possíveis travamentos ou até aquecimento da bateria.
Se alguém puder me ajudar, agradeço!
Obrigado!
Minha versão instalada é a: OPMI.WW_Phone-15.2016.1902.340-20190216
Nem sei se é a versão estável oficial ou beta a que tenho instalada. Só sei que gosto do jeito que tá e é por isso que estou com medo de atualizar e acabar não gostando.
Abraço.
