Model Name: Asus ZM Pro m1
Firmware Version: (QKQ1.WW_Phone-17.2017.2006.
429-20200614)
Rooted or not: no
Frequency of Occurrence:
I would like to thanks asus, for providing android 10 beta 3 for max pro m1. I had updated my device today morning and using it since 5 hrs. Belive me or not my experience is amazing. This beta 3 is very close to the stable update. Many bugs are fixed in this update.
1) very important, pubg can be run in hd graphics and high frame rates ( thank you asus)
2) pubg experience was very smooth. I had played in smooth+ high settings.
3) After 1hr of gaming my battery drain was only 14%. It was amazing, battery backup felt to be good.
4) Sound from speaker is very loud. Asus has done impressive work in terms of sound quality (thanks again).
5) I didn't notice any lagg after updating my device.
I think this update is close to the stable one. I will post my full review after using it properly.
Thank you Asus....
