Quick Settings Tiles Misfunctions
vishallagoo
Model Name: Asus Zenfone Max Pro M2
Firmware Version: 105
Rooted or not: Not Rooted
Frequency of Occurrence:
Some of quick setting tiles are mis-behaving. For Example, as you can see in screenshot, even if battery saver is actually off in settings, still battery saver on icon is visible in notification bar and quick setting tiles. Even sometimes tapping battery saver or location quick setting, it turns on/off actually, but quick setting icon doesn't change.
This issue I observed for Battery Saver, Location, Focus Mode only. Please check.
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check for any disturbance from the installed 3rd party apps.
3. If still you face the issue factory reset your phone after
taking a full backup: https://www.asus.com/support/FAQ/1006346/
vishallagoo
Yes i already tried these steps, but nothing solved my issue. I think it might be system firmware bug.
