Problems in Android 10 beta 2 of asus max pro m1
hmankoo22
1 volume of media‚ ringtone of alarm and call are low than Android 9
2 on homescreen google search bar cannot be removed
3 in settings there are some suggestions which cannot be removed
4 screen is not properly round at the corners
5 when u use dark mode on third party apps . Some apps like facebook and snapchat not properly get black in dark mode
6 battery is draining very fast in this update and screen on time of battery is about of 2 days but it cannot even survive 1 day and the battery usage tell us wrong percentage of heavy games like i play pubg adout 2 hr and it drain about 50 percentage and in phone its tell that pubg use 10 percentage please fix this issue.
7 on home screen when u swipe right on screen sometimes the page of google appear but sometimes it not appear.
5 REPLIES 5
Christine_ASUS
Community Legend II
Hi mssivasangaran
Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
1. Please clean the debris off the port with compress air can.
Your issues can cause by various reasons, a common reason is the port had too many debris, so that the port keep detect debris or moisture. Please try to clean your port with soft tools (e,g. compressed air can) or bring it back to Repair Center for device checking.
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
3. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
